Discussion topic: Q box WiFi drop out
Message posted on 28 May 2025 08:55 PM
Q box WiFi drop out
Hi recently my sky Q box has been constantly dropping its WiFi connection. Nothing has changed with the set up at all. It's now happening daily. Never had an issue till recently.
Message posted on 28 May 2025 08:56 PM
Re: Q box WiFi drop out
Hi @Sneeve
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
