Discussion topic: Sky remote
This message was authored by: Centurygo
Sky remote
The dismiss button om my remote needs pressing very hard to work, Worried it won't work at all soon
Re: Sky remote
Hi @Centurygo
Try giving the buttons on your remote a wipe with a soft damp brush.
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
