Discussion topic: Sky remote not working
This message was authored by: BlueBox123
My remote isn't working so I cannot operate my sky
Re: Sky remote not working
Hi @BlueBox123
Check that the batteries are new.
Then first reboot your Q box.
Then Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
