Discussion topic: Sky Q mini box
Message posted on 27 Jul 2023 08:07 PM
Sky Q mini box
Keeps turning itself off and on
Message posted on 27 Jul 2023 08:14 PM
Re: Sky Q mini box
Hi @Caper+08
If the issue with the mini continues try a Reset Settings in the mini box hidden menu.
Message posted on 27 Jul 2023 10:53 PM
Re: Sky Q mini box
Thank you have just rebooted the mini box so fingers crossed thank you
Message posted on 30 Jul 2023 01:07 AM
Re: Sky Q mini box
Have rebooted both boxes and still sky mini going off my bt internet was checked it's completely fine so must be a faulty box
