1
This discussion topic has been answered Discussion topic: Sky remote keeps brining up the channel banner by itself.
This message was authored by: Stevethepunk
My sky remote keeps brining up the channel banner by itself. I have reset the sky box and changed the batteries but it is still happening. The buttons do not seem to be stuck and nothing has been spilt on the remote.
Re: Sky remote keeps brining up the channel banner by itself.
Hi @Stevethepunk
Hi @Stevethepunk
