Discussion topic: Q box slows down response from handset, scree goes blank and then goes into stanby
This message was authored by GB761 This message was authored by: GB761
Sky q box goes slow in responding to handset  picture goes and then goes into standby mode. Unpredictable in FF and rewind.
Re: Q box slows down response from handset, scree goes blank and then goes into stanby
Hi @GB761
GB761
Thanks for that, but although the green light is on, the screen is blank and not responding to the home button!
Hi @GB761
Reboot the Q box.
If you have to press the standby button on the front on the Q box to bring it on then, with the Q box on with green led try completly resetting your Bluetooth remote.
