Discussion topic: Sky remote isn’t working
Message posted on 13 Dec 2023 08:14 PM
My remote has stopped working. You sent me a new one, it says to hold buttons 1&3 and follow instructions on screen but nothing comes on the screen. The red light on the remote flash's but nothing happens. Can you help please? I've tried ringing but struggling to speak to someone.
Message posted on 13 Dec 2023 08:22 PM
Re: Sky remote isn’t working
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
Message posted on 13 Dec 2023 08:23 PM
Tried that but still not working
Message posted on 13 Dec 2023 08:33 PM
The Q box needs to be on with green led when you try to pair .
First reboot your Q box .
Then try completly resetting your Bluetooth remote.
Message posted on 16 Apr 2024 02:29 PM
My sky q remote stopped working this morning, following the instrutcions on your site about ptessing digits 7 + 9 3 or 4 times, then 1+3 it still did not work, so i unplugged the sky q box, reset all the settings and tried the remote again and it worked, so there is another way to reset the remote.
Message posted on 23 Apr 2024 03:30 PM
Can anybody help?,
My remote for the sky q box has stopped working, it has new batteries.
I have tried the holding 7 & 9 and holding 1 & 3, that made no difference.
I have also tried restarting the box but it still doesn't work.
any ideas?
Message posted on 23 Apr 2024 08:01 PM
Try unplugging it, then restarting the box, then do what you've already done with the buttons, that's what i did and the remote started after, that's all i can suggest, Noel
Message posted on 24 Apr 2024 12:06 AM - last edited: 24 Apr 2024 12:06 AM
In the short term press and hold 4 + 6 to turn it into an IR only remote so you can Atleast control the box.
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 24 Apr 2024 07:38 PM
Thank you for this information. I have been struggling with the remote not pairing to the TV and had tried pressing 7/9 and 1/3, turning the TV, sky box etc on and off several times.
When I pressed 4 and 6 together, the remote started working and I could access the sky controls. Then pressing 7/9 and then 1/3 reset everything.
Thank you so much.
Message posted on 25 Apr 2024 12:55 PM
Re: Sky remote nit working
Press 1 snd 7 together until remote control red LED flashes then press 1 and 3 together until red LED flashes and follow on screen instructions.
Message posted on 25 Apr 2024 01:21 PM
Tried all these options but none worked and this is a new box and remote very annoying
Message posted on 25 Apr 2024 06:26 PM
You mean 7+9 and 1+3?
Message posted on 25 Apr 2024 07:08 PM
All sorted now thanks
Message posted on 08 Aug 2024 02:51 PM
I've put new batteries in prest 7-9 together iam not getting no response on the tv remote nothing not working it's not the first time this as happened
Message posted on 16 Aug 2024 10:34 PM
How did you link the remote back up? This is so annoying!! I don't see any led lights and I've tried the 7 and 9 and then the 1 and 3, and the 4 and 6 and reset 😔
