Discussion topic: Sky remote code for finlux model 50MU35F
This message was authored by: snooker1471
I just bought a new Finlux 50MU35F and the sky remote will not work to control volume. I've tried various codes but none working..
Any suggestions.
Do I need to reset remote to remove old TV etc. many thanks
Re: Sky remote code for finlux model 50MU35F
Any suggestions.
@snooker1471 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for snooker1471
I have tried that but when following on screen prompts it seems the TV code isn't found.
