Discussion topic: Sport via sky Q
Message posted on 19 Aug 2026 05:47 PM
Sport via sky Q
New LG oled purchased but sports not as clear as old plasma.
Guy un currys says I need to upgrade from Q to streaming?
Message posted on 19 Aug 2026 06:11 PM
Re: Sport via sky Q
@Mick56B wrote:New LG oled purchased but sports not as clear as old plasma.
That would be unusal - it would indicate a setup issue with the LG. My LG (a rather aging 65CX5) produces an amazing picture on HD and UHD source.
Plasma's were generally bright but quite low resolution.
Er, no. 'Upgrade' is subjective.
Message posted on 19 Aug 2026 06:16 PM - last edited: 19 Aug 2026 06:20 PM
Re: Sport via sky Q
hi @Mick56B
It may be worth playing with the TV's settings - I think that sometimes 'out of the box' modes can be a bit fierce with some of the processing
One thing if you don't subscribe to UHD (i.e. only watch HD cannels etc) then probably best to set the resolution on the SKY Q box to 1080 not 2160 as the TV is likely to upscale better than older SKY Q box (Plasma TVs of course were only HD)
Message posted on 19 Aug 2026 06:19 PM
Re: Sport via sky Q
hi @Mick56B
One thing if you don't subscribe to UHD (i.e. only watch HD cannels etc) then probably best to set the resolution to 1080 not 2160 as the TV is likely to upscale better than older SKY Q box (Plasma TVs of course were only HD)
Yup, the LG default settings can be a bit 'overpowering'. I run mine in film maker mode as I found frame interpolation artefacts annoying.
Message posted on 19 Aug 2026 06:38 PM
Re: Sport via sky Q
hi @Mick56B
@Mick56B in addition to @nigea99 post do you have hdmi ultra hd deep color set to on in the settings as you need this on to get HDR when watching in UHD
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
