Discussion topic: Sky q
Message posted on 14 Aug 2024 12:23 PM
Sky q
We have just had 2 sky q boxes fitted at the pub box 1 isn't switching on there is an orange lighy but it wont go blue , so currently we don't have any sound!
Message posted on 14 Aug 2024 12:36 PM
Re: Sky q
Hi @Foresttown
If you are referring to Sky Q boxes the Amber light on the box is also a standby button.
It doesn't turn blue but should turn Green when the Q box is on.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 14 Aug 2024 01:43 PM - last edited: 14 Aug 2024 02:29 PM
Re: Sky q
@Foresttown wrote:We have just had 2 sky q boxes fitted at the pub box 1 isn't switching on there is an orange lighy but it wont go blue , so currently we don't have any sound!
As this is a pub, you might want to call Sky Business for support: 03308 083 302
