Discussion topic: Sky q
This message was authored by: SteveTLF
Sky q
My sky Q boxes keeps freezing and showing an orange light on the front …the only way to fix is to turn off and on again and I have had a message saying a problem with hard disc drive .
Re: Sky q
Hi @SteveTLF
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Ordering a new Q box usually means a doorstep swap.
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi -in din socket in the back of the Q box.
See below.
