Discussion topic: BOTH SKY Q BOXES HAVE NO SIGNAL
This message was authored by: shadysbt1
BOTH MY BOXES HAVE NO SIGNAL
Re: BOTH SKY Q BOXES HAVE NO SIGNAL
@shadysbt1
If a message is displaying ”No signal” it tends to be from your TV (in which case check the HDMI cable between the Sky Q box and your TV).
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
It’s not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
