Discussion topic: Hello, my mini sky box is not connecting. I would like to speak to an advisor. Thank you.
Message posted on 09 Mar 2024 04:48 PM
Hello, my mini q box is not connecting. I would like to speak to an advisor. Thank you.
Message posted on 09 Mar 2024 04:53 PM
Re: Hello, my mini sky box is not connecting. I would like to speak to an advisor. Thank you.
Then you need to call to speak to someone.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Hi @Janese
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home]
Regarding your issue.
Reboot the mini as above.
