Discussion topic: Sky q won’t connect to fibre
Message posted on 02 Jan 2026 01:57 PM
Yesterday my sky q stopped connecting to the bb. Reset everything several times tried holding the wps button nothing happens. Normal sky tv is still working just won't connect to the WiFi. Never happened before really frustrating
Message posted on 02 Jan 2026 05:17 PM - last edited: 02 Jan 2026 05:19 PM
Re: Sky q won’t connect to fibre
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party broadband (non Sky or Sky Max router ) then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 02 Jan 2026 09:18 PM
Message posted on 03 Jan 2026 12:24 AM
Me too! My Sky Q box kept dropping it's internet connection, so I tested my Lila fibre broadband & it is working perfectly. Then I called Sky customer services & they sent out a new/replacement Sky Q box, but that's doing the same as the old one. I get it connected, then, when I turn on my TV the following day, it's dropped off the internet again. So, if it's not my broadband & not the Sky Q box, what else can it be??? Am getting really frustrated, as am paying for a service I'm not getting......
