Discussion topic: Sky q was installed yesterday. Within 5 minutes of the engineer leaving it had lost broadband.
This message was authored by: Norma54
Broadband cuts out every half hour! It takes another half hour to sort itself out...not good
Re: Sky q was installed yesterday. Within 5 minutes of the engineer leaving it had lost broadband.
Hi @Norma54
Failing this best to contact Sky directly to get the Engineer back
