Discussion topic: Sky q touch remote not working
This message was authored by: Hihn
Message posted on 17 Apr 2023 09:17 PM
My sky q touch remote is not working with the box says it's lost signal but can't get it to work
Find out more
Message posted on 17 Apr 2023 09:36 PM
Re: Sky q touch remote not working
Hi @Hihn
Try completly resetting your remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
