1750
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky q switches off - 15/05
Locked
This message was authored by: Repairman42
Failing SkyQ box
Watching YouTube the picture and sound suddenly cut off and the box with green light and blue rotating indicator fails to respond to remote. Unplugging the box restores everything but it will fail again after ten minutes or so. This pattern continues until I give up trying.
This message was authored by: Dubnine
Re: Sky q box freezing
Hi check my original message software updates. See if it helps
This message was authored by: SussexWolf
According to Sky it's fixed, so I suggest trying to reboot again this morning and hopefully your box should remain operating.
Re: Sky q switches off - 15/05
Sky's post about the problem and what to do this morning:-
https://www.sky.com/help/servicestatus/tv
This message was authored by: Fbac0101
SkyQ mini boxes can’t connect to main box
Having an issue where at least once a day, I have to unplug and plug back in my sky Q mini boxes, as they say they can't connect to the main sky Q box. I have a sky booster which is connected but the issue still happens. the boxes are all over 2 years old.
ive tried restarting the main box but still having issues. Any help on fixing this would be greatly appreciated
Re: No connection to sky Q box
@Sand19 therexwas a mjor outage on Sky Q last night which has now been fixed but you may need to rdboot your box by switching off the power for 30nseconds. If howver thst isnt your problem post again.
This message was authored by: RichardP1
My Sky Q box switches off after about 15 minutes of watching a recorded program..
The only way to get it running is switch off the box, switch on , and the let it reboot. This is really irritating.
By the way, is it possible to contact Sky for an eingineer vist to resolve this and an occasional los of signal caused by a poor positioning of my Skydish ?
Sorry, to hear, maybe reset your router then try the process again
This message was authored by: Darran5
Re: My sky won't stay on
No. It's in for a period of time say 10 minutes then goes off. The remote won't turn it back on. The only way to turn it back on is to take out the plug. Put it back in and it goes back in. But then it turns off again around 10 minutes later
This message was authored by: Chris290668
Aha,  was just about to post a thread about this after speaking with Netflix.
Wasn't sure if it was Netflix or Sky Q as I usually watch Netflix through Sky Q. Was watching the third episode of a new series on Netflix via Q last night, and three times while watching the programme just stopped leaving a blank screen Q box off but the blue light spinning as if it was recording. I rebooted Sky Q but it kept happening. I updated the Sky Q software, but issue happened again. I then managed to watch the remainder of the programme without issue on Netflix app on my TV. But I then (as a test) returned to Netflix via Q and watched an episode of something else later and no issues occurred at all plus watching other stuff on Sky Q seemed fine so was a tad baffled as it seemed to only happen when I watched this particular new series on Netflix via Q?  No error messages just blank unresponsive screen which required unplugging and rebooting from the mains plug.
This message was authored by: Jaeger36
I did the reboot around 09:45 and do far it's holding both picture and sound 🤞
Re: Getting error code mr104
Did the reboot at around 09:45 and so far so good 🤞
This message was authored by: WindyBuffs
I had this last night, at about 10:00pm. I was watchig a recording and then the screen went blank and the Sky Q box was frozen, and not responding to the remote handset. I had to unplug the box from the mains, about 5 times before I gave up. It's a relief this morning to know that it was a technical issue with Sky, and not my box. Thanks for posting this - I thought it was just me that had the problem!
This message was authored by: Theresa27
Thank you - I'm back on - after lots of cursing!
everyone remember to physically turn on your Sky Q box after rebooting - then it should work .
Re: My Sky Q box switches off after about 15 minutes of watching a recorded program..
Yes.
Locked
Answered - Go to Answer
