1750
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky q switches off - 15/05
Locked
This message was authored by: Raptor606
Re: Latest Sky Q software version
Well if it's not the software update what is causing this really annoying problem ?  Impossible to watch anything because the box continually freezes, as described by others who commented above.  Luckily my TV has Freeview and I have an old Freesat box but can't watch any Sky channels or recordings because of this freezing problem.  Really thought my box had failed until reading all the similar reports above.
This message was authored by: SkreamQween
Re: My Sky Q box keeps randomly switching off in the middle of a programme and has to be unplugged.
Can't get the box to work to try your helpful advice
This message was authored by: LB158
Re: Having trouble with my sky tv .
Many people having this problem this evening including myself. Very frustrating
This message was authored by: Jo063
Re: Sky Q keeps crashing
Same here in Leeds crashes out
This message was authored by: lendilou
Re: No response
Yep. Had to turn off at plug for times in just over an hour. Have given up with it now. Had to leave it unplugged for the night. Hopefully will be resolved by sky tomorrow. So many having the same issue tonight
This message was authored by: Nothingbetter2do
Re: Sky q switches off
To resolve the issue
Go to settings > setup > preferences > turn off smart standby and set standby to active
So far, so good for me, all the boxes are working again
This message was authored by: ASPM722
Re: Sky q box switching off
Can't even get to settings. Won't let us past the no signal notice.
This message was authored by: bathanza
Turn off from mains. Plug in. Allow for box to load and quickly get into settings.
This message was authored by: Philly8
Same here, I live in New Milton Southern England.
This message was authored by: ajb12
Sky Q box lost signal
Sky Q box keeps losing signal restart good for 10 minutes loss signal
This message was authored by: Rick2510
I found that after a SkyQ switch off, if I immediately disconnect the Qbox from the mains, wait 1 minute and then reconnect. The normal start up process begins and the box eventually displays the yellow light. If after a minute or so I then switch on from the Sky remote the light turnd green and  home screen immediately re-appears. It then takes the usual time to load the page up fully.
If I was watching a recorded program and select that , it will return to the start and not to where it was at the disconnection.
That suggests to me that the fault is an intermittent one that is short lived.
This message was authored by: SussexWolf
So far, also working for me.
This message was authored by: TheOne
I've not mady any config changes on SkyQ and it seems to of fixed itself. I'm guessing Sky's reverted a feature flag to stop the troubled app.
This message was authored by: melt123
Same in Norfolk
Locked
Answered - Go to Answer
