Discussion topic: Sky q switches off - 15/05
Message posted on 15 May 2025 11:31 PM
Re: Sky Q box keeps switching itself off?
Mine keeps turning itself off this evening. Just goes to the No Signal screen, then nothing happens, won't react to the remote, have done the Reset. Only thing that works is turning off at the socket. I'm watching something, then when I go back it 'continues' from a point I'd seen a while ago, not where it cut out.
Any thoughs or advice?
Cutting out
Watching tv or recordings sky goes off says select source. Can't turn sky box off or do anything. Have turned plug off and reset 3 times after about 15 mins goes off again WHY
Message posted on 15 May 2025 11:32 PM
Re: Sky q switches off
Same here in Portsmouth - if reset sky q box works for about 10 or 15 mins and then switches off
Tv keeps going off
I cant get hold of sky live hat with a agent when I go to sign in page its blank
sky boxes will not connect to
q mini boxes will not connect to system
Re: Sky+ keeps crashing
We're having the same. It keeps crashing whilst watching a netflix series. We've had to reboot 3 times
Re: No signal
I am in Southend and my TV keeps reading no signal. I had gone off on me 3 times tonight
Re: Sky Q box frozen
Same problem as me !
Yup. We thought our box needed replacing until reading this. Definitely something with Sky.
No sky tv
No sky TV sky q box keeps turning itself off and freezing as it won't power down or up have lost count of how many times gave rebooted it my sky app not working either
Message posted on 15 May 2025 11:33 PM
Re: Sky Go keeps saying an error message
My sky mimi box
Re: Every so often the picture just goes blank, cannot do anything and have to unplug the Sky Q box
Amen to that. Definitely something untoward going on, for everything to be down at the same time, tv service and app, plus the website struggling too.
Re: Sky Q
Bully for you... it's blew me PlayStation
what's the record number of posts to one thread on here? Can we set a new record?
Same happening to me!! Every 20mins!! Does anyone have a fix?? 🙂
