Discussion topic: Sky q switches off - 15/05
Message posted on 15 May 2025 11:16 PM
Re: Sky App and TV not working
Same here and I was watching something I'd recorded ! 😤
Re: Sky q switches off
This happened to me earlier. Said needed a software update which it did. Now every 20minutes screen goes black then no source. Have to unplug and start again for Sky to work for it all to happen again in 20 minutes time. 4 times this cycle has happened. Fed up
Re: Sky stopped working…can’t reconnect!
Mines the same, I've unplugged everything reset changed batteries used different remotes and no response from any (I've still nothing) 🤷🏻♀️
Re: No response
Mine has switched off 3 times in the last 2 hours. Switched off at wall, left for 30 secs, turned back on and each time is back working........waiting for it to happen again!!
Yes, sky q keeps switches off
Viewing recordings problems
Whilst watching recordings the sky Q box switches off and has to be unplugged and rebooted to work again, the Q sign is red with a blue ring around it
Message posted on 15 May 2025 11:17 PM
Sky box keeps switching off. We switched off at wall and reset. Happening every 10-15 minutes. Thought it was our box until I found these comments. We are in Inverness.
Same here in Warrington. 5 or 6 times tonight.
Same here.its been stable since I did it
Re: Sky Q box still showing working but no picture coming through
I am having the same issue in notts
Reboot then OK for a while
I've switched off and seems ok now
Sky q going off and getting black screen
Sky q going off and getting black screen. I then have to turn it off then it comes back on.
Re: Sky+ keeps crashing
Sky Q box keeps crashing every 5-10 mins. Reboot. Same things happens. Tried turning off Standby mode. Made no difference.
Sky Q switching off but green light stays on
Hi, today my Q box switched itself off , but the green light remained on. The remote then does not work and the only way is to unplug and reset. All is fine, then It repeats , 10 mins or so later. I have done a basic reset (not full or factory as that is the nuclear option).
any ideas please?. When it switches off, the remote no longer works and will only work with a power reset.
many thanks in advance
Message posted on 15 May 2025 11:18 PM
Sky Q not working
Why is sky Q buffering and can't get it to work? Keeps losing signal and I have read others having same problem this evening. Cut off three times. Then again while watching a recording! Green light in the box but not responding. I've switched off at the wall twice now! No better
