Discussion topic: Sky q switches off - 15/05
Message posted on 15 May 2025 10:51 PM
Re: Sky q box showing no signal with green light on
Well come back to the 1960s few more babies made to night without the TV ..............!
Blank screen box seems to lock up
Our sky q box keeps stopping, no signal displayed on tv screen. Box doesn't respond to remote or buttons on the front. Switching off at the wall and restarting the box work's for a few minutes
Same where I am in Suffolk
Message posted on 15 May 2025 10:51 PM - last edited: 15 May 2025 10:54 PM
Re: Latest Sky Q software version
@Mog01 wrote:Snap ! Bloody frustrating!! Just updating manually now🤞
That won't do anything apart from forcing your box to restart. Looking at other threads, there is a major problem with thousands of customers, so it's not a local issue
https://helpforum.sky.com/t5/Sky-Q/Sky-q-switches-off/td-p/4983961
Message posted on 15 May 2025 10:52 PM
Re: Sky q switches off
One thing that I have noticed is that my SKY Q box top is no longer very warm or hot as it always seemed to be. Tonight it is cool. Might just be coincidental but something I noticed when resetting the power after switching it off at the plug sockets before switching on again after 20+ seconds. The picture seems to last around twenty minutes before shutting off with the green light still on and the remote will not do anything whatvever you try.
Yes, it's exactly the same for me. Have rebooted 3 times now within half an hour. Come on Sky , stop saying there is no problem , and get it sorted . There is clearly an issue here !
3 times unplugging and it plays for 10 min then goes blank on the TV. Light on the Q box but nothing. Completely frozen. Not happy
Having the same issue from about 9:15. Reset by disconnecting from the mains and eventually returned to service; only for it to switch off again15 minutes later.
Noticed that even though Sky Q becomes disconnected on screen, the box remains on and cannot be switched off using the remote.
Broadband is functioning fine and no other tests indicate an issue, though obviously there is as happening to several users.
Re: Q box keeps shutting down
seems to be widespread issue tonight
I have had the same issue 3 time in the last hour, very frustrating.
Sky Q problems
My Sky Q signal keeps freezing tonight.
Is Sky having problems ?
I have the same issue. Twice shut off the output and needed a power off to recover.
Sky keeps turning off
Message posted on 15 May 2025 10:53 PM
Re: Sjy q box turning off every 20 mins.
Appears to be widespread issue tonight
- Coincidence that I can't log into the website and the app is down for maintenance???
