1750
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky q switches off - 15/05
Locked
This message was authored by: Bill1968
Re: Sky q switches off - 15/05
Tried that. Box won't even come out of standby!
This message was authored by: Dubnine
Re: Sky q box switching off
  • Cool , good news
    @Herts+22 wrote:
    They rolled back the update to the last version that was working properly.
This message was authored by: Sand19
No connection to sky Q box
No WiFi connection
This message was authored by: mctoodles
Sky q box freezing
My sky q box started freezing last night every 20 minutes or so. Each time it stopped the connection to the tv dropped as the box stopped sending any output. No buttons worked on the box or remote. The only way to get it to restart was to turn it off remove the power cable and restart the box. This happened about 4 times. I restarted before bedtime but it was frozen again this morning. Again removing power was the only way to get it to restart. When I have checked the box through the sky app, it says it is all ok. Do I just need a new box?
This message was authored by: DI73
I have no signal - tried turning off and staring again several times.  Any ideas???
This message was authored by: Amandakee
Sky Q box
The sky box keeps switching off and won't switch back on
That box i sounds broke. Could be a hard drive problem
Need to converse with sky
Sorry to hear that
Re: Sky q box freezing
hi @mctoodles  as you will see it has been a major problem across many SKY Q boxes - thus not just your box
This message was authored by: CLAIRTHOMAS
Outage in Ireland
Looks like it's not resolved in Ireland, I have the Technician booked for Monday, should I cancel or will you be addressing this?
This message was authored by: SussexWolf
You have no choice but to unplug the box from the mains, leave off for 30 seconds, and then plug back in. It should then boot as normal. Hopefully the fix Sky have rolled out will prevent it recurring.
This message was authored by: Theresa27
Still cannot re-connect my Sky Q Box at 09.50 Friday morning.
Whatever is the problem ??
This message was authored by: AndrueCope
Interestingly the software version of my box is now later (Q310) than the stated version on their website (Q300) so they've either rolled back the update or issued a new one.
Check my original message about software updates. See if it helps. Hope you get it sorted
This message was authored by: Neet1
Done that, no luck
This message was authored by: Jenefc1
Sky box crashing
Have anyone had issues last night with the sky box crashing all the time.
Locked
Answered - Go to Answer
