This discussion topic has been answered Discussion topic: Sky q remote will not set up
Message posted on 14 Oct 2024 04:19 PM
Hello
Damaged sky q remote so bought a new one
I have tried and tried all instructions given more than a few times and cannot get remote to work
When I press 1 - 3 together the remote flashes but does nothing else does not bring page up to set up
I have done the 7 - 9 to disconnect and then the 1-3 to set up nothing
What am I doing wrong
Please help
Message posted on 14 Oct 2024 07:04 PM
Hello
Thank you so much it's working
Obviously something was in the way
I went and stood in front of the box and started doing it's thing straight away
Thank you Thank you
Lucky someone knows what they are doing x
Message posted on 14 Oct 2024 04:57 PM
Re: Sky q remote will not set up
@Karenlulu wrote:
Hello
Please help
@Karenlulu Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 14 Oct 2024 05:40 PM
Hello
Thank you for your reply
I have reset the box I have done all the sequences on the emote I have put the box on standby
But the remote does all the lighting up but will not bring the Page up on screen for me to set up the new remote I am completely at a loss
Message posted on 14 Oct 2024 05:45 PM
@Karenlulu wrote:
Hello
Hi @Karenlulu
If the remote led flashes 4 times when you press and hold 7 & 9 together then it doesn't look like it is faulty.
When you press 1 & 3 together to re pair the remote, the Q box needs to on with green led and you must be pointing the remote directly to the Q box.
@Karenlulu wrote:
Hello
hi @Karenlulu
Could there be anything blocking the signal from the remote to your box - until it is paired it needs direct line of sight as it works in infrared
Hello
Thank you Thank you
