This discussion topic has been answered Discussion topic: Sky q remote controls another TV.
Message posted on ‎20 Jan 2024 01:55 PM
I have just put a Samsung TV in another room and my Sky q remote in the next room ( also a Samsung} switches on and off when I use controller. I even set up controller using the exact model number.
How can I stop this remote controlling another TV.
Message posted on ‎12 Aug 2024 05:55 PM
Message posted on ‎20 Jan 2024 02:03 PM
Re: Sky q remote controls another TV.
hi @Doddsy
Are you using a SKY mini box or are you using an HDMI splitter ?
Message posted on ‎20 Jan 2024 02:13 PM
Hi. It's a sky q mini box.
Message posted on ‎20 Jan 2024 02:26 PM
Message posted on ‎20 Jan 2024 02:29 PM
Hi. The other TV is close, separate room but no wall between.
Message posted on ‎20 Jan 2024 02:36 PM - last edited: ‎20 Jan 2024 02:37 PM
hi @Doddsy
In which case the other TV seems to be able to receive the remote signal - this can be more likely if your walls might reflect the signal easily.
If they are both the same make of TV this can happen (a problem with all IR remotes)
I am not aware of anyway to change TV remote codes.
I have a panasonic dvd/HDD freeview & separate blu-ray player that allow me to change code to prevent conflict but, as I say, I am not aware of any TVs that have this
You could possibly locate the IR sensor on the TV and see if you could shield it slightly with a peice of card or something.
Message posted on ‎20 Jan 2024 02:45 PM
ok, thanks for trying . Cheers
Message posted on ‎12 Aug 2024 05:28 PM
Did you manage to fix your issue??
I have the same problem.
