Discussion topic: Sky Q mini box says You can't watch TV at the moment as there is a connectivity problem.
This message was authored by: Phil+Daley
Re: Sky Q mini box says You can't watch TV at the moment as there is a connectivity problem.
Hi @Phil+Daley
Reboot the mini as above.
