Discussion topic: Sky q problems
This message was authored by: Wendy27
Sky q problems
Sky q box keeps loosing WiFi signal, having to reset almost daily.
Re: Sky q problems
Hi @Wendy27
Who is your Broadband supplier and how are you resetting your Q box?
Avatar for Wendy27
Re: Sky q problems
Hi, my supplier is sky, and I have to press the w something button on my sky wifi box, then have 2flashing amber lights, then searchs sometimes it loads other times it says unsuccessful connection, this is now happening 3 to 4 times a week but I cannot get through to sky, many thanks
Avatar for Wendy27
Sky q
Sky or any body please help me, my sky q box keeps loosing WiFi signal it's WiFi signal, I'm having to re set on a daily basis now and just getting fed up with it, any help would be be appreciated, thank you.
Re: Sky q
@Wendy27 have you tried rebooting your router then trying to connect your main box to the router
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
