Discussion topic: Sky q pin reset
This message was authored by: Lar7
Sky q pin reset
When I go to reset pin from my sky it's not prompting to use bank account it just says reset pin and I can't remember pin
Re: Sky q pin reset
@Lar7 the default pin number is the last 4 digits of your viewing card number
You can find your viewing card number by pressing home scrolling down to settings then system info
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Sky q pin reset
Hi @Lar7   Have a look here for PIN help https://www.sky.com/help/articles/your-pin
