Discussion topic: Mysky 2306
This message was authored by: Tracy23061
Mysky 2306
Can anybody please tell me how to sign into paramount or hbo max I've tried calling and he said he had fixed the issue but still can't access them Tia
Re: Mysky 2306
Have you activated HBO Max via Sky by following the instructions here: Sign up to HBO Max
Do you have a Sky Cinema subscription which includes Paramount+ or are you signing up directly?
Either way, if everything is activated and set up correctly, you should be able to login using the email address you used during sign up.
