Discussion topic: Sky q not working
Message posted on 12 Jan 2024 06:16 PM
Sky q not working
My sky q mini box won't connect to the internet
Message posted on 12 Jan 2024 06:30 PM
Re: Sky q not working
@Mark155 Have you tried rebooting your main Q box ie
then
reboot your mini
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Message posted on 12 Jan 2024 06:47 PM
Hi @Mark155
Try a Network Reset on the mini.
