Discussion topic: Sky q box glitching
This message was authored by: DLR78mc
Sky q box glitching
Had a Q box fitted on Monday and it is constantly glitching on the screen/flashing white/interupts speaking on shows
Re: Sky q box glitching
Hi @DLR78mc
