Discussion topic: Sky q not responding
This message was authored by: IanHoneyman
Have your advertising page only
nit responding to remote
Re: Sky q not responding
@IanHoneyman Have you tried rebooting your main Q box ie
If that doesnt help then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
