Discussion topic: Sky Q box not connecting to new TV
Message posted on 11 Jun 2024 05:09 PM
Sky Q box won't connect to new LG 4k tv.
Message posted on 11 Jun 2024 05:22 PM
Re: Sky Q box not connecting to new TV
@Imonthwaitengin wrote:Sky Q box won't connect to new LG 4k tv.
Connect in what way? No video/audio or is it the remote you are struggling to pair with the TV?
Check the HDMI connection and make sure you have selected the appropriate HDMI input using the LG remote.
Message posted on 11 Jun 2024 05:33 PM
I get a constantly flickering screen with normal sky menu in the background. They sent me a new HDMI cable but same issue.
Message posted on 11 Jun 2024 05:35 PM
