Discussion topic: No satellite coming through my sky my sky, Q
Message posted on 11 Jun 2024 04:32 PM
I have no satellite come through my sky a box
Message posted on 11 Jun 2024 04:35 PM
Re: No satellite coming through my sky my sky, Q
Do you mean no satellite signal?
A “no satellite signal” message relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
If you’re on a communal dish you’ll need to liaise with your landlord or building management company who will deal directly with their approved engineers.
