Discussion topic: Sky q multiroom not working
This message was authored by: Cf-26
my internet dropped including the wifi yesterday and finally managed to reboot the router and get the broadband and wifi back. TV in main sky q box working fine but the mini box in the other room won't work. Ive tried rebooting it / un plug / resync the wifi nothing is helping it is just showing a screen saying no connection found
Re: Sky q multiroom not working
Hi @Cf-26
Reboot the mini as above.
Avatar for Cf-26
Hi Thanks for the advice I did all those things but it is still not working
Hi @Cf-26
Try moving the mini temporary to your main Television.
Plug the Mini into a spare HDMI input in the TV and see if it will connect there.
