Discussion topic: Sky q mini box
This message was authored by: Bengraham16
Sky q mini box
Just got a sky q mini box trying to set it up connects to the wifi no problem but still comes up with no satallite signal and can't watch any tv
Re: Sky q mini box
Hi @Bengraham16
Unless you are on Sky Broadband when using WiFi your mini will only connect to the main Q box or another mini or Q WiFi Booster.
If on Sky Broadband it can also connect to your Router.
Reboot the mini as above.
Re: Sky q mini box
@Bengraham16 just checking  you didget the mini box from Sky and you do have the multiscreen subscription
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
