1
This discussion topic has been answered Discussion topic: Sky q mini box
This message was authored by: Nei3
Sky q mini box
My sky keeps stuttering I think the box has had it
Re: Sky q mini box
Hi @Nei3
Reboot the mini as above.
Re: Sky q mini box
Hi @Nei3
