Discussion topic: Sky Q No Satellite Signal
This message was authored by: Neill01
Having an intermittent problem with Sky Q box for the last week  - unable to watch any tv channels.  Can watch some recordings but not always.  Error message says 'No satellite signal' , just a blue screen.
Can't get hold of anyone to help & first available engineer appointment is in 2 weeks.
Can anyone suggest anything to help here please?
thanks
Re: Sky Q No Satellite Signal
@Neill01
Whenever a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
