Discussion topic: Cannt change channel
This message was authored by: WAP8Y
About once a month my Mini Box doesn't allow you to change channel by controller or Voice.  I have to Re-boot every time. There is no Wi-Fi problem or power cuts to cause the problem
Re: Cannt change channel
Hi @WAP8Y
With the mini box on try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
