9
This discussion topic has been answered Discussion topic: Sky q just looping a advert for sky
This message was authored by: Tom+halifax
So the other day I turned on my tv with sky a box and all I have on the screen is a sky q advert saying helpful hints and tips and I cannot get rid of it.
This message was authored by: Quoman7 Answer
Re: Sky q just looping a advert for sky
@Tom+halifax wrote:
So the sky isn't even on a channel all it is doing is playing the same sky q advert about tip and tricks over and over again not a single button on my remote works apart from the volume button and yes I have changed the battery's
@Tom+halifax Have you tried resetting the remote?
Hi @Tom+halifax Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Avatar for Tom+halifax
I have done this and nothing !!
@Tom+halifax so when you try to change channels with your remote the SKY box stays on the same channel? Try resetting your remote:-
Press and hold 7 and 9 together on your Sky remote for three seconds. Press and hold 1 and 3 together for three seconds.
This message was authored by: Invisiblename
@Tom+halifax @Quoman7  Sounds like it's on channel 998.  Does your remote control still turn your Sky & TV on & off? What happens when you try & change channel? If you press 'i' on your remote does the info banner come up?
I am just another Sky customer!
This worked !!! Amazing many thanks
This message was authored by: RDuncan
Literally had this happen to me tonight. Turns out that the "4" button was stuck down thus stopping any other buttons working. Duh!
This message was authored by: Ella7
Worked for me thank you so much!
