Discussion topic: Constant Sky box reset
This message was authored by: Tree-Man
How often should I have to reset my Sky Q box to fix a reported technical fault with a channel ?
Is every other day normal?
Why is my system so unstable ?
Re: Constant Sky box reset
@Tree-Man what channel are you having problems with and what is the fault ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
