Discussion topic: Sky q getting stuck on standby
Message posted on 24 May 2023 08:00 PM
Over the last week or so my sky q box won't come of standby when I try and turn it on
Message posted on 24 May 2023 08:02 PM
Re: Sky q getting stuck on standby
Hi @Matthew+118
