Discussion topic: sky q mini disxonnexting from internet
Message posted on 24 May 2023 08:12 PM
My sky Q mini box keeps disconnecting from the Internet. At beginning was few rimes a week now up to 6 times a day. Have a autistic daughter and am getting very frustrated. 2 hours on phone and got nowhere
Message posted on 24 May 2023 08:21 PM
Re: sky q mini disxonnexting from internet
Hi @kiera+eng
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
