Discussion topic: Sky q frozen on 1 of 2 updates tried all steps hours later still frozen why it’s a joke
Message posted on 19 Mar 2024 09:56 AM
Sky q frozen on 1 of 2 updates tried all steps hours later still frozen why it’s a joke.
Message posted on 19 Mar 2024 04:38 PM
Re: Sky q frozen on 1 of 2 updates tried all steps hours later still frozen why it’s a joke
@RyanFirth96 have you tried unplugging you box from the socket for 20 minutes then plugging it back in
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 19 Mar 2024 05:53 PM
Hi @RyanFirth96
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 19 Mar 2024 06:01 PM
Finally just got sky back all day long still not sure what resolved the issue I just kept repeating the turning off steps, I did change the port but not sure if it made a difference.
The remote had to be re paired and we've lost all recordings ect.
Sky was not at all helpful but Thankyou both for suggestions
