Discussion topic: Can’t connect new sky mimi box
Message posted on 19 Mar 2024 02:48 PM
Can't connect my mini box
Message posted on 19 Mar 2024 04:12 PM
Re: Can’t connect new sky mimi box
Hi @Janice0602
Reboot the mini as above.
