Discussion topic: Sky q connection problems
Message posted on 18 Jul 2024 07:23 PM
I currently have one sky q box and 3 minis, up until a few days ago they have all worked well except for an occasional glitch. For the last two days the connection between the minis and the main box keeps going down and the network connection also keeps going despite it working on all other devices in the house. Has something happened in the last few days to cause these problems?
Message posted on 18 Jul 2024 07:30 PM
Re: Sky q connection problems
Who is your broadband supplier @andyharris2
Message posted on 18 Jul 2024 07:43 PM
Virgin media
Message posted on 18 Jul 2024 08:09 PM
@andyharris2 wrote:
Virgin media
All I can suggest @andyharris2
is a complete reset of your mini boxes connection.
Reboot the minis as above.
If the mini still do not connect try a Network Reset on the minis. Start with the one nearest to the main Q box
. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
