Discussion topic: My sky isn’t working
This message was authored by: Dianelhill
Several times I've had you out with the same issue I have no signal on my tv it's been like this several days the past few weeks so I cannot watch tv I'm paying for a product off you that the same issue keeps re occuring
Re: My sky isn’t working
@Dianelhill
This is a customer helps customer forum so you’re not contacting Sky Customer Services by posting on here.
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
