Discussion topic: Sky q box.
This message was authored by Karl26 This message was authored by: Karl26
Sky q box.
New sky q box needs rebooting every time after it has been put on standby.
Re: Sky q box.
Hi @Karl26
I assume you are not using it in the early hours if it is in Eco Standby
https://www.sky.com/help/articles/using-the-standby-settings#:~:text=Changing%20the%20standby%20sett....
Karl26
Re: Sky q box.
No I am not. I have put it in active mode but having same problem. Also have updated software twice.
Re: Sky q box.
Hi @Karl26
Whenyou select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
Might be worth trying Reset Settings in the Q box hidden menu if you haven't already.
Karl26
Re: Sky q box.
Ok will try this. Only got the new sky q box yesterday. Seems strange the new sky q box has the exact same problem my old sky q box had. I was hoping by getting a new sky q box I wouldn't be having the same problems.
Karl26
Re: Sky q box.
Reset the sky q box. Another issue, Tv screen has now frozen. Sky q box unresponsive by remote and sky q box making a terrible sound.
Karl26
Re: Sky q box.
Anyone know the phone number  I can speak to a human being at sky please? Constantly rebooting sky box as won't work.
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Sky q box.
@Karl26
If you definitely need to call Sky you can call free by dialling 150 from a Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
▪️ I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
