Discussion topic: Network connection problem
This message was authored by: DTRUBY
Hi I'm unable to get, apps. On demand, catch up and sky movies when I look with remote control, it says I have no internet connection but I have it on my laptop and phone, we have tried all the trouble shooting but still does not work
Re: Network connection problem
Hi @DTRUBY
