Discussion topic: Sky q box not working
This message was authored by: Ralphfred
Hi   my sky q box will.not select any channels just get unavailable messages on all channels .  Rewind and fast forward was also failing to work yesterday.
Have reset box but problem persists.
Re: Sky q box not working
Hi @Ralphfred
If you only have done a reboot try a Reset Settings in the Q box hidden menu.
