Discussion topic: Sky q box not working
Message posted on 11 Jun 2025 02:25 PM
Hi my sky q box will.not select any channels just get unavailable messages on all channels . Rewind and fast forward was also failing to work yesterday.
Have reset box but problem persists.
Message posted on 11 Jun 2025 06:26 PM
Re: Sky q box not working
Hi @Ralphfred
If you only have done a reboot try a Reset Settings in the Q box hidden menu.
